Hi
This is my problem:
I recording some show and i use
Bus A & B = Reporter (2 persons in vmix call) Bus B = Production (2 persons in vmix call) Everybody hearing B son the reporter can ear the cue.
So i send A to masters for the record.
But i use my microphone to talk to production and reporter on Bus B. I ear myself in my microphone. This anyway i case mute my microphone in my headphone.
Important: I use the option mute microphone in headphone, but when i talk in bus, it doesn't work.
Please help me to correct my setup, to mute my headphone.
Thanks: 64 times Was thanked: 153 time(s) in 137 post(s)
One possibility: If you have set Bus A and B to a specific device In Settings / Audio Outputs you should set them to "Enabled".
If that doesn't help: What are your settings in Audio Outputs for Master and Headphones?
Originally Posted by: dmwkr  One possibility: If you have set Bus A and B to a specific device In Settings / Audio Outputs you should set them to "Enabled".
If that doesn't help: What are your settings in Audio Outputs for Master and Headphones? First thank for your help. You have to know that i have 2 ouput in my soundcard Back output = Speaker Front output = Headset So in my Audio setup in vmix i try those 2 setup and both doesn't work. Setup 1. (No sound of B in my Headset) Master = Backout output Headphone = Front output Bus A= Enabled Bus B= Enabled Setup2. (ear myself back in headset) Master = Backout output Headphone = Audio playback Device Bus A= Enabled Bus B=Front output Please save me
I've been looking for a good setup for myself, and it is similar to your Setup 1.
Edit: Sorry, I think I had it wrong. I have also bus C enabled, route every input I want to hear there (so everything but the mic) and solo bus C (click the S on bus C in the Audio Mixer), and Setup 1 should work. Then, bus C is what you hear through your headphones, minus your input.
There are probably other ways to do it. You have to keep trying to find what is the best workflow for you.
 1 user thanked dmwkr for this useful post.
Originally Posted by: dmwkr  I've been looking for a good setup for myself, and it is similar to your Setup 1.
There are probably other ways to do it. You have to keep trying to find what is the best workflow for you. Never think of that solution... I try it and it's working. Maybe not the perfect way. But for now it's working. Thank you very much :)
