ClementN
#1 Posted : Tuesday, April 21, 2020 5:51:55 PM(UTC)
ClementN
Romania
There are situations when we need to manually move trough the rows and go trough a set of them multiple times until the show is ended.
I think it will be a good addition to be able to restart from row 1 when the last row is reached IF the existing button "Loop" is selected.
Thank you very much,
#2 Posted : Tuesday, April 21, 2020 6:05:39 PM(UTC)
As you are advancing manually one can
- have a shortcut to jump to the first one
- have a script to check and jump to the first one
(until this is implemented)
ClementN
#3 Posted : Tuesday, April 21, 2020 9:57:21 PM(UTC)
ClementN
Romania
Very good suggestions.
(until this is implemented) :)
Thank you.
