Feature Requests
DataSourceNextRow restart from row 1 when Loop selected
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
There are situations when we need to manually move trough the rows and go trough a set of them multiple times until the show is ended.
I think it will be a good addition to be able to restart from row 1 when the last row is reached IF the existing button "Loop" is selected.
Thank you very much,
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
As you are advancing manually one can
- have a shortcut to jump to the first one - have a script to check and jump to the first one
(until this is implemented)
Very good suggestions.
(until this is implemented) :)
Thank you.
Feature Requests
