Joined: 4/19/2020(UTC) Posts: 5  Location: TN Thanks: 1 times
I installed an AVerMedia card and it shows up in the camera input list but not the camera's name. Vmix says something like Capture Device Is Not Supported. Any suggestions? I tried moving the resolution since I saw in another post that it could be one of the reasons why but still nothing. Thanks all.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Which card? Have you downloaded the latest drivers? vMix edition? What are your input settings, What is the camera resolution etc etc.... There are so many things it could be.......details help
Avermedia card, I downloaded all the drives, 720x480 resolution, I tried HDM1 and VGA inputs.
Which Model card? Again the more detail you provide the easier it is to help. The volunteers here on this forum are not mind readers or have powers to see your PC. You have to describe as much as possible.
C875, I already updated vmix, I really don't know what else to add. But thanks for your reply.
OK. That is NOT a capture card! It is designed to be an encoder/recorder. However you can, sort of, use it as a capture device. To do this you need to to download and install Stream Engine. https://www.avermedia.com/us/product-detail/C875Note: Stream Engine for this model was only released as a beta and there was limited support for different resolutions.
I already downloaded the stream engine. It also shows up in the camera input list.
Originally Posted by: sierra  Vmix says something like Capture Device Is Not Supported Does this give you a clue?
 1 user thanked ask for this useful post.
