xemles
#1 Posted : Friday, April 17, 2020 11:15:11 AM(UTC)
xemles
France, Metropolitan
Hello, I have a problem with Virtual PTZ on an AMD computer, I precise it because it doesn't seem to have the problem on others pcs, basically what happens is that whenever I connect Virtual PTZ, the screen just "turns off". Here's an example: https://imgur.com/a/GYtvyfm
I don't know if you can do anything about it, but I don't have this issue when I put vMix on another PC. This one is a freshly installed OS and everything else seems to work fine except this.
