Joined: 11/25/2019(UTC) Posts: 42  Location: Bordeaux Was thanked: 2 time(s) in 2 post(s)
Hello, I have a problem with Virtual PTZ on an AMD computer, I precise it because it doesn't seem to have the problem on others pcs, basically what happens is that whenever I connect Virtual PTZ, the screen just "turns off". Here's an example: https://imgur.com/a/GYtvyfmI don't know if you can do anything about it, but I don't have this issue when I put vMix on another PC. This one is a freshly installed OS and everything else seems to work fine except this.
