Hardware Compatibility
Skaarhoj control surface as a vMix vision mixer panel
Joined: 10/15/2018(UTC) Posts: 17  Location: Worcester, UK Was thanked: 1 time(s) in 1 post(s)
hi everyone Has anyone managed to use a Skaarhoj control surface as a vMix vision mixer panel? I have an E201-M16 which I have managed to get talking to vMix but there is a very limited choice of functionality on the drop down menu to choose from.  IMG_6132.jpg (213kb) downloaded 1 time(s).The main problem is that whilst one can cut to a source using the 'Active Source' option it won't then play the clip if it is a video. Similarly the 'Cut' option doesn't specify which camera one is cutting to so one can't use it instead. Therefore the only way to play a video is to select it to preview and then cut to it when it will then play, you can't directly cut to it as it will just show a still frame. Furthermore there is no Stinger transition option either. Has anyone had any success in solving this problem? I may have to resort to buying an X-Keys but I already have the Skaarhoj and if I can just increase its functionality it would be fabulous. Kind regards Steve Ryder steve.ryder@stryder.tv
Joined: 3/25/2019(UTC) Posts: 38  Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
