StryderTV
#1 Posted : Thursday, April 2, 2020 12:27:13 AM(UTC)
StryderTV
hi everyone
Has anyone managed to use a Skaarhoj control surface as a vMix vision mixer panel? I have an E201-M16 which I have managed to get talking to vMix but there is a very limited choice of functionality on the drop down menu to choose from.
The main problem is that whilst one can cut to a source using the 'Active Source' option it won't then play the clip if it is a video. Similarly the 'Cut' option doesn't specify which camera one is cutting to so one can't use it instead. Therefore the only way to play a video is to select it to preview and then cut to it when it will then play, you can't directly cut to it as it will just show a still frame. Furthermore there is no Stinger transition option either.
Has anyone had any success in solving this problem?
I may have to resort to buying an X-Keys but I already have the Skaarhoj and if I can just increase its functionality it would be fabulous.
Kind regards
Steve Ryder
steve.ryder@stryder.tv
Le-bo2d9
#2 Posted : Saturday, April 25, 2020 8:43:14 AM(UTC)
Le-bo2d9
Hi Steve,
you can maybe check this
https://www.skaarhoj.com/support/device-cores/vmix/
Guest (4)
