andreypetr
#1 Posted : Thursday, March 26, 2020 10:38:49 PM(UTC)
andreypetr
Hello. I would like to add some panning/zooming effects to my camera input, to make it more dynamic. Is it possible in vMIX?
I would imagine it as a keyframe animator.
#2 Posted : Friday, March 27, 2020 1:46:50 AM(UTC)
sure you could
if you check the input settings there is a position option , there are also shortcut function to set these values.
if you play with that i a script you could do all sort of funny movements
Or you could use a simple virtual set and pan/zoom that way too
One can also play with the Merge transition to go from one position to another
andreypetr
#3 Posted : Friday, March 27, 2020 2:45:27 AM(UTC)
andreypetr
Originally Posted by: doggy Go to Quoted Post
sure you could
Thanks for quick reply. If I am going with a script changing the coordinates route, does it mean that I have to manually figure out 100-1000 positions for smooth animation? Is there a command that moves inputs by 1 or 2 pixels?
#4 Posted : Friday, March 27, 2020 3:41:33 AM(UTC)
in a script (thats the point of it) one can program a loop say
step from 0 to 1000
step +1
set position @ step
Next
PS this is not real code , just the jest of it
Guest (4)
