Is it possible to animate Inputs?
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Hello. I would like to add some panning/zooming effects to my camera input, to make it more dynamic. Is it possible in vMIX?
I would imagine it as a keyframe animator.
sure you could
if you check the input settings there is a position option , there are also shortcut function to set these values. if you play with that i a script you could do all sort of funny movements
Or you could use a simple virtual set and pan/zoom that way too
One can also play with the Merge transition to go from one position to another
Originally Posted by: doggy  sure you could
Thanks for quick reply. If I am going with a script changing the coordinates route, does it mean that I have to manually figure out 100-1000 positions for smooth animation? Is there a command that moves inputs by 1 or 2 pixels?
in a script (thats the point of it) one can program a loop say
step from 0 to 1000 step +1 set position @ step Next
PS this is not real code , just the jest of it
