jeffbrown1966
#1 Posted : Monday, March 23, 2020 7:15:11 AM(UTC)
jeffbrown1966
We use V-Mix for live stream and it works fine but we would like to have the ability to record the audio as a separate file to post for the church web site with out having to record it separately, we post the video/audio mix to FB now but would like a separate audio file to post also.
The worship pastor gets the audio that was recorded on a CD Burner from the sound board then puts it on Itunes and up loads it to sound cloud, there has to be a better way?
Any direction would be helpful.
Thank you for your time.
Jeff
elvis55
#2 Posted : Monday, March 23, 2020 7:38:04 AM(UTC)
elvis55
Switzerland
Hallo
You can set that in Record. Click on - WAV File Record - and a separate audio will be recorded.
WAV File Record
