Joined: 11/20/2017(UTC) Posts: 3   Location: Oklahoma City, OK
We use V-Mix for live stream and it works fine but we would like to have the ability to record the audio as a separate file to post for the church web site with out having to record it separately, we post the video/audio mix to FB now but would like a separate audio file to post also.
The worship pastor gets the audio that was recorded on a CD Burner from the sound board then puts it on Itunes and up loads it to sound cloud, there has to be a better way?
Any direction would be helpful.
Thank you for your time.
Jeff
Joined: 3/17/2017(UTC) Posts: 452  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 57 time(s) in 51 post(s)
Hallo You can set that in Record. Click on - WAV File Record - and a separate audio will be recorded. WAV File Record
