Rank:: Newbie
Joined: 3/22/2020(UTC) Posts: 6  Location: Lindon Thanks: 1 times
Have USB cameras (Logitech C930e and Logitech C920) input to VMix. Only in VMix the preview and output screens flicker. System camera app shows no flicker.
Have NVidia GEForce MX130 Have updated NVidia drivers VMix using NVidia in settings
Help Please.
Alan
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
Rank:: Newbie
I checked Logitech for webcam drivers as per the thread. Logitech itself does not seem to have specialized drivers. I found "driversupport.com" but searching on it gives me concern whether it is legit.
Rank:: Newbie
Just checking some more. That thread mentioned recurrence of flicker after upgrading to USB 3.0. My Lenovo has USB 3.0 hub. could that be the problem?
Alan,
One of my new computers is a Dell 2-in-1 with an mx230 with a c920, a c930e, and a c925e It’s exhibiting the same unstable graphics that you mention when using the latest nVidia drivers When I disable nVidia, vMix behaves properly, so I have done that, at least temporarily I don’t know if this is a vMix issue or an nVidia issue... or both.
 1 user thanked AlanZ for this useful post.
Rank:: Newbie
Just tried same cameras on an older HP Envy computer. No nVidia. Appears to be very stable. Will try disabling NVidia.
Rank:: Newbie
Need help to disable NVidia.
In VMix, went to settings > Performance. The only selections are: "Default" and "NVdia" Default goes to NVdia.
Any other way to disable NVidia?
Alan,
close vMix, and in the nVidia control panel, in the 3D settings page, turn the display adapter to auto-select instead of the high performance adapter
Rank:: Newbie
with the NVidia disabled, the camera flicker disappeared. I could display both cameras and a multiview. Received my USB 3.0 HUB, plugged both camera into this hub. Now I can only have 1 camera. VMix generates a system resource error when adding the second camera. (either one)
Further, Tried the same setup on older HP Envy PC HP Envy generated the same error.
It would appear that VMix has a problem with USB 3.0
My workaround Use the older HP envy laptop since the cameras are stable on it and it has 4 USB ports eliminating the use of USB hub.
I don't know if or when VMix will get happy with USB 3.0.
What else could I do?
Alan, do not plug two USB 2.0 cameras into a usb2 or usb3 hub. Your cameras are all usb 2.0 so they really need to be on separate usb channels
Joined: 7/15/2018(UTC) Posts: 110  Location: Las Vegas, NV Thanks: 14 times Was thanked: 9 time(s) in 7 post(s)
If I can add to this discussion - I had zero issue with the camera flickering until I performed a fresh install on Windows 10 today. Now I am having the flickering issues he is speaking about.
Joined: 7/26/2020(UTC) Posts: 1  Location: Adelphi, Washington
