SRT
SRT - Technical/System Requirements
Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Hi all From the manual  But further down it says  I'm not 100% sure what they are trying to say? Is a supported graphics card a requirement or not? I suspect they meant to say A supported graphics card is highly recommended but you can use software via CPU encoding if you want? Then the next question is, what is the recommended CPU/RAM requirements for CPU/software encoding? Thanks
The SRT is the protocol, not a codec, I don't think there is any specific requirement to the decoding capabilities of the GPU. The only requirement is Windows 10. I tested SRT on different PCs, including those with "integrated graphics" and everything worked fine.
Interesting
What resolution, frame-rate and encoding type were you testing with? (HEVC or H264)
I was referring to SRT inputs, not outputs which do require encoding (H.264 or HEVC). Encoding takes advantage of GPU, sorry for the confusion.
SRT
