ispyisail
#1 Posted : Saturday, February 29, 2020 6:04:50 PM(UTC)
ispyisail
Hi all
From the manual
But further down it says
I'm not 100% sure what they are trying to say? Is a supported graphics card a requirement or not?
I suspect they meant to say
A supported graphics card is highly recommended but you can use software via CPU encoding if you want?
Then the next question is, what is the recommended CPU/RAM requirements for CPU/software encoding?
Videostream
#2 Posted : Tuesday, March 3, 2020 11:34:15 AM(UTC)
Videostream
The SRT is the protocol, not a codec, I don't think there is any specific requirement to the decoding capabilities of the GPU.
The only requirement is Windows 10.
I tested SRT on different PCs, including those with "integrated graphics" and everything worked fine.
ispyisail
#3 Posted : Tuesday, March 3, 2020 1:29:18 PM(UTC)
ispyisail
Interesting
What resolution, frame-rate and encoding type were you testing with? (HEVC or H264)
Videostream
#4 Posted : Tuesday, March 3, 2020 10:28:03 PM(UTC)
Videostream
I was referring to SRT inputs, not outputs which do require encoding (H.264 or HEVC).
Encoding takes advantage of GPU, sorry for the confusion.
Guest (6)
