martyp
#1 Posted : Saturday, February 29, 2020 7:44:06 AM(UTC)
martyp
Canada
Hi, We are using vMix 23 with a AJA Kona 4 capture card.
https://www.aja.com/prod...NBAp1EAAYASAAEgKXO_D_BwE
We can assign an HD-SDI output from the card but cannot assign the HDMI out to vMix(vMix to Kona 4 HDMI)
We get the following options for outputs in the vMix menu
- None
- Kona 4 SDI 1
- Kona 4 SDI 2
- Kona 4 SDI 3
- Kona 4 SDI 4
- Sample Output
No indication of assigning the Kona 4 HDMI output!
We've tested the HDMI out from the Kona 4 without vMix and it does work so it looks like vMix is not seeing the HDMI output from the Kona 4 for some reasons.
NiBTour
#2 Posted : Saturday, February 29, 2020 9:00:50 AM(UTC)
NiBTour
I know for the io 4K if you want hdmi out you would do:
HDMI input
Select IO4K Input 2 as the Camera and HDMI as the Input
HDMI output
Select IO4K Output 1 as the Device and HDMI as the Port
as well as there was a multi-channel tool to assign SDI4 as the output and such. might want to giveb that a try.
-King
- None
- Kona 4 SDI 1
- Kona 4 SDI 2
- Kona 4 SDI 3
- Kona 4 SDI 4
- Sample Output
martyp
#3 Posted: : Saturday, February 29, 2020 9:59:34 AM(UTC)
martyp
Canada
That's from within vMix or the AJA application?
I don't need any HDMI inputs We have 4 HD SDI cameras and we need to output 1 output HDMI
