AJA Kona 4 HDMI OUTPUT ISSUE
Hi, We are using vMix 23 with a AJA Kona 4 capture card. https://www.aja.com/prod...NBAp1EAAYASAAEgKXO_D_BwEWe can assign an HD-SDI output from the card but cannot assign the HDMI out to vMix(vMix to Kona 4 HDMI) We get the following options for outputs in the vMix menu - None - Kona 4 SDI 1 - Kona 4 SDI 2 - Kona 4 SDI 3 - Kona 4 SDI 4 - Sample OutputNo indication of assigning the Kona 4 HDMI output! We've tested the HDMI out from the Kona 4 without vMix and it does work so it looks like vMix is not seeing the HDMI output from the Kona 4 for some reasons.
Joined: 3/28/2016(UTC) Posts: 168   Location: SACRAMENTO Thanks: 6 times Was thanked: 23 time(s) in 21 post(s)
I know for the io 4K if you want hdmi out you would do: HDMI input Select IO4K Input 2 as the Camera and HDMI as the Input HDMI output Select IO4K Output 1 as the Device and HDMI as the Port as well as there was a multi-channel tool to assign SDI4 as the output and such. might want to giveb that a try. -King Originally Posted by: martyp  Hi, We are using vMix 23 with a AJA Kona 4 capture card. https://www.aja.com/prod...NBAp1EAAYASAAEgKXO_D_BwEWe can assign an HD-SDI output from the card but cannot assign the HDMI out to vMix(vMix to Kona 4 HDMI) We get the following options for outputs in the vMix menu - None - Kona 4 SDI 1 - Kona 4 SDI 2 - Kona 4 SDI 3 - Kona 4 SDI 4 - Sample OutputNo indication of assigning the Kona 4 HDMI output! We've tested the HDMI out from the Kona 4 without vMix and it does work so it looks like vMix is not seeing the HDMI output from the Kona 4 for some reasons.
That's from within vMix or the AJA application?
I don't need any HDMI inputs We have 4 HD SDI cameras and we need to output 1 output HDMI
