cambysys
#1 Posted : Saturday, April 19, 2014 12:51:18 AM(UTC)
cambysys
Version = vMix Basic HD - 12.0.0.111 x64
Running under win 8.0 native boot on macbook air mid 2012
8GB ram and (now I have freed up) 6GB disk space.
I am streaming to youtube.
Slowly the available space on C drive is reducing.
Yesterday when I had less free space to start with it ended up with zero free space on C and then hung. When I rebooted I was back to my previous few hundred meg of free space. I then experimented and while vMix was running the disk space would reduce. Stopping vmix and restarting it returned the free space.
These are the free space readings at 1 min intervals today.
6 731 280 384
6 719 549 440
6 707 359 744
Streaming to youtube. 1280x720
1500kb/s
on a 100MB/s NBN connection.
1 video input from a Pinacle dazzle composite to USB device. The input in vMix is set to widescreen.
Audio is from Tascam US-122
as an aside, if I stream using Adobe Flash Media encoder then I get no disk usage but I do get crackles in the audio. I do not think Adobe is getting the right number of bits from the tascam.
cambysys
#2 Posted : Sunday, April 20, 2014 9:54:03 AM(UTC)
cambysys
I think its hiberfil.sys
#3 Posted : Sunday, April 20, 2014 6:49:38 PM(UTC)
First make sure you are using the latest version of vMix downloadable from the web site.
There have been a few updates since .111
Second, from the Streaming window in vMix look under the Advanced tab to make sure you aren't saving
the stream as well.
cambysys
#4 Posted : Tuesday, April 22, 2014 6:47:39 PM(UTC)
cambysys
Thanks for the reply Martin. I will down load the new version. I do not think that I was recording it but its over now. I will set up a test and try again soon.
