STADIORADIO
#1 Posted : Friday, February 21, 2020 12:43:29 AM(UTC)
STADIORADIO
Hello, I would like to have Wmix perform operations automatically. I looked through the options on the triggers, but I can't find anything that would make a play or transition to a set time. Can you help me. Thank you
vmixgreg
#2 Posted : Friday, February 21, 2020 1:50:27 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Hi STADIORADIO
vMix does not have or support time-of-day scheduling, but will work with the "OnCountdownCompleted" Trigger, so if you want to trigger something in 1 hour and 42 minutes 37 seconds, if you create a timer to countdown from that time, it will work.
Using the PlayList feature is another option, but again, not time-of-day, only timed.
Not necessarily the most convenient solutions but the only ones that are available to use directly in vMix.
Alternative solutions would be scheduling applications developed for vMix:
- vTask: https://forums.vmix.com/...-and-Scheduling-for-vMix
- vScheduler: https://forums.vmix.com/...ing-for-playback-in-vMix
- Super Basic vMix Scheduler: https://forums.vmix.com/...per-Basic-vMix-Scheduler
- vMix Scheduler: https://forums.vmix.com/...cheduler---alpha-release
Please note, as these are all third party applications, vMix does not provide support for them, but as far as I know, they all work with vMix.
I hope that helps.
thanks 1 user thanked vmixgreg for this useful post.
STADIORADIO on 2/21/2020(UTC)
