Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
Hello, I would like to have Wmix perform operations automatically. I looked through the options on the triggers, but I can't find anything that would make a play or transition to a set time. Can you help me. Thank you
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 67 Location: Canada
Thanks: 1 times Was thanked: 20 time(s) in 19 post(s)
Hi STADIORADIO vMix does not have or support time-of-day scheduling, but will work with the "OnCountdownCompleted" Trigger, so if you want to trigger something in 1 hour and 42 minutes 37 seconds, if you create a timer to countdown from that time, it will work. Using the PlayList feature is another option, but again, not time-of-day, only timed. Not necessarily the most convenient solutions but the only ones that are available to use directly in vMix. Alternative solutions would be scheduling applications developed for vMix: - vTask: https://forums.vmix.com/...-and-Scheduling-for-vMix - vScheduler: https://forums.vmix.com/...ing-for-playback-in-vMix - Super Basic vMix Scheduler: https://forums.vmix.com/...per-Basic-vMix-Scheduler - vMix Scheduler: https://forums.vmix.com/...cheduler---alpha-release Please note, as these are all third party applications, vMix does not provide support for them, but as far as I know, they all work with vMix. I hope that helps.
 1 user thanked vmixgreg for this useful post.
