antardwip
#1 Posted : Wednesday, April 16, 2014 5:13:33 PM(UTC)
antardwip
OK - I have been unsuccessful with getting my TP-Link sc-3230 to work with vMix, using rtsp://[my ip address]:554/video.mp4 so I tried the utility and got this:
RTSP/1.0 200 OK
CSeq: 1
Content-Base: rtsp://[my ip address]:554/video.mp4/
Content-Type: application/sdp
Content-Length: 252
v=0
o=- 2208990726 2208990736 IN IP4 127.0.0.1
s=Video Server Session
c=IN IP4 0.0.0.0
t=0 0
a=control:*
a=range:npt=0-
m=video 0 RTP/AVP 26
a=control:trackID=1
m=audio 0 RTP/AVP 97
a=rtpmap:97 G726-32/8000
a=fmtp:97
a=control:trackID=2
Are there any clues there suggesting if the camera can possibly work or not?
Thanls a lot,
ys
Streamevent
#2 Posted : Thursday, April 17, 2014 3:30:59 AM(UTC)
Streamevent
This works for my sc-3230N:
rtsp://[my ip address]:554/h264/video.h264
or have a look here:
http://www.ispyconnect.com/man.aspx?n=tp-link
antardwip
#3 Posted : Thursday, April 17, 2014 5:14:27 AM(UTC)
antardwip
Thanks! Your model is the same as mine, with wireless. That is very hopeful.
However, mine still doesn't work (I also tried some of the settings from ispyconnect)
Is the ip address you used the same address you put in a browser window to view the camera (that allows you to get the settings etc?)? That's the ip address I am using.
ys
ps my intranet is working as I have a Teredek cube up and running.
Streamevent
#4 Posted : Thursday, April 17, 2014 8:30:44 AM(UTC)
Streamevent
try to disable audio in the camera settings.
with audio on it also not working for me.
antardwip
#5 Posted : Friday, April 18, 2014 5:21:23 AM(UTC)
antardwip
Amazing - thank you so much:
and disable audio, and it works.
God bless you.
