Should this ip camera address work in stream input?
OK - I have been unsuccessful with getting my TP-Link sc-3230 to work with vMix, using rtsp://[my ip address]:554/video.mp4 so I tried the utility and got this:
RTSP/1.0 200 OK CSeq: 1 Content-Base: rtsp://[my ip address]:554/video.mp4/ Content-Type: application/sdp Content-Length: 252 v=0 o=- 2208990726 2208990736 IN IP4 127.0.0.1 s=Video Server Session c=IN IP4 0.0.0.0 t=0 0 a=control:* a=range:npt=0- m=video 0 RTP/AVP 26 a=control:trackID=1 m=audio 0 RTP/AVP 97 a=rtpmap:97 G726-32/8000 a=fmtp:97 a=control:trackID=2
Are there any clues there suggesting if the camera can possibly work or not?
Thanls a lot,
ys
Joined: 8/18/2013(UTC) Posts: 43 Location: Switzerland
Thanks: 1 times Was thanked: 5 time(s) in 4 post(s)
Thanks! Your model is the same as mine, with wireless. That is very hopeful. rtsp://[my ip address]:554/h264/video.h264 However, mine still doesn't work (I also tried some of the settings from ispyconnect) Is the ip address you used the same address you put in a browser window to view the camera (that allows you to get the settings etc?)? That's the ip address I am using. ys
ps my intranet is working as I have a Teredek cube up and running.
try to disable audio in the camera settings. with audio on it also not working for me.
Amazing - thank you so much: rtsp://[my ip address]:554/h264/video.h264
and disable audio, and it works.
God bless you.
