Soccer score clock countdown
Joined: 8/16/2016(UTC) Posts: 8 Location: The Netherland
Hi Guys,
I have a question, due to my bad scripting i would like to now if it is possible to adjust the "start-time" on a countdown by a trigger.
when the clock pauzes at 45 minutes i would like to create a button or a script whom i can adjust te starting time of my countdown.
i know that i can adjust the countdown sequence by seconds and the set/adjust/change countdown and this works flawlessly.
the thing i would like to achief is when my clock stops a 45 minutes i have one button on wich i can change the start time to 45 mins with an countdown duration of 45 mins so i have at the end 90 minuts.
can this be done by scripting or somekind ?
Best Regards,
Dennis
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
First thing that comes to mind because I do not recall shortcut for start time changing..
Edit your title, duplicate the timer field, rename first field "pre_45" and second one "post_45" If you are using GT Titles, go to "Data" tab and tick the "Show Visible Toggle" checkbox on both fields. Then hide the "post_45" field in the layers list.
Now in vMix configure your pre and post fields as pre counts 0 to 45 and post counts 45 to 90. Create different shortcuts for both. For hiding pre and showing post use "SetTextVisibleOn / Off" functions.
