I would like to mount a small camera upside down on the ceiling. Is there a way within vMix to rotate the camera output 180 degrees?
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 69 Location: Canada
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
Hi Johnny,
Yes, you can rotate a vMix Input 180 degrees. Click the Input's cog wheel Click the Position tab Make sure you are adjusting "Main" in the dropdown menu Adjust the Rotate [Z] button slider (3.141593 should do it)
vMix Greg
 1 user thanked vmixgreg for this useful post.
Thanks, it works like a charm.
Inverting upside-down works great, but I'd like to flip the image from left to right... for instance, if a christmas tree is over the person's left shoulder, I want to see it over their right shoulder. The x and y axis position just turns the image, with the image always looking the same. Thank you for any help!
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
I believe that in the input settings there is a mirror option.
Nice! Thanks!
I finally found it in the "General" Tab of the Input Settings.
