JohnnyBG
#1 Posted : Wednesday, February 12, 2020 12:50:57 AM(UTC)
JohnnyBG
I would like to mount a small camera upside down on the ceiling. Is there a way within vMix to rotate the camera output 180 degrees?
vmixgreg
#2 Posted : Wednesday, February 12, 2020 1:13:00 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
Hi Johnny,
Yes, you can rotate a vMix Input 180 degrees.
Click the Input's cog wheel
Click the Position tab
Make sure you are adjusting "Main" in the dropdown menu
Adjust the Rotate [Z] button slider (3.141593 should do it)
vMix Greg
thanks 1 user thanked vmixgreg for this useful post.
Lennart on 2/12/2020(UTC)
JohnnyBG
#3 Posted : Wednesday, February 12, 2020 4:12:25 AM(UTC)
JohnnyBG
Thanks, it works like a charm.
Shawn Payne
#4 Posted : Wednesday, December 16, 2020 7:55:37 AM(UTC)
Shawn Payne
Inverting upside-down works great, but I'd like to flip the image from left to right... for instance, if a christmas tree is over the person's left shoulder, I want to see it over their right shoulder. The x and y axis position just turns the image, with the image always looking the same.
Thank you for any help!
andreypetr
#5 Posted : Wednesday, December 16, 2020 8:08:49 AM(UTC)
andreypetr
I believe that in the input settings there is a mirror option.
Shawn Payne
#6 Posted : Wednesday, December 16, 2020 8:32:22 AM(UTC)
Shawn Payne
Nice! Thanks!
I finally found it in the "General" Tab of the Input Settings.
