GT
Fill GT graphics with datas
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi, I want try to fill lower thirds with names and flags for a Triathlon event.
I've got an excel file with athletes name, number and nationality.
Are there any way to do that?
Quote:Hi, I want try to fill lower thirds with names and flags for a Triathlon event.
Thanks Yes there is Its one of the basic (a lower third is a title) things titles and datasources are used for check the multiple (video)tutorials about vMix titles, datasources and alike A search in this forum helps also
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: dmwkr  Even simpler if your data holds just a country code like "ITA" you can refer to a local folder holding national flags with such name and refer to it with : d:/Myflags/{0}.jpg in the datasource settings for d:/Myflags/ITA.jpg
GT
