rinaldo
#1 Posted : Thursday, January 30, 2020 10:58:28 PM(UTC)
rinaldo
Hi, I want try to fill lower thirds with names and flags for a Triathlon event.
I've got an excel file with athletes name, number and nationality.
Are there any way to do that?
#2 Posted : Thursday, January 30, 2020 11:51:06 PM(UTC)
Yes there is
Its one of the basic (a lower third is a title) things titles and datasources are used for
check the multiple (video)tutorials about vMix titles, datasources and alike
A search in this forum helps also
dmwkr
#3 Posted : Friday, January 31, 2020 12:07:09 AM(UTC)
dmwkr
...and additionally, you can use file paths in your excel file for the flags:
https://www.vmix.com/hel...m?DataSourcesImages.html
#4 Posted : Friday, January 31, 2020 12:11:57 AM(UTC)
Even simpler
if your data holds just a country code like "ITA" you can refer to a local folder holding national flags with such name
and refer to it with :
d:/Myflags/{0}.jpg in the datasource settings for d:/Myflags/ITA.jpg
dmwkr on 1/31/2020(UTC)
