Haone1234
#1 Posted : Wednesday, January 22, 2020 2:32:23 PM(UTC)
Haone1234
Vmix ndi capture was working fine with Windows 7. Updated to windows 10 and now I have to reinstall vmix ndi desktop capture every time I start the computer.
Desktop capture won't start, without reinstall. Crashes every time I click on the icon. Any suggestions? Thanks.
JohnBush
#2 Posted : Thursday, January 30, 2020 6:45:14 PM(UTC)
JohnBush
Are you using Windows 64 bit??
I had an issue trying to stream and record with 32 bit version of Windows 10 and it didn't work (Can't access over 3 gb of ram even if you have 16 installed)
John
