NDI
Windows 10 and Vmix ndi capture problem
Hello, Vmix ndi capture was working fine with Windows 7. Updated to windows 10 and now I have to reinstall vmix ndi desktop capture every time I start the computer.
Desktop capture won't start, without reinstall. Crashes every time I click on the icon. Any suggestions? Thanks.
Are you using Windows 64 bit?? I had an issue trying to stream and record with 32 bit version of Windows 10 and it didn't work (Can't access over 3 gb of ram even if you have 16 installed)
John
NDI
