Simsyuk
#1 Posted : Saturday, January 18, 2020 1:01:03 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
IS anyone having problems today with vMix, my stream is just terrible (my connection is all ok, over 200mb). It's so slow. I'm trying to update to version 23.0.0.37 and it's taking over 20 minutes to install!
#2 Posted : Saturday, January 18, 2020 2:23:25 AM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
If you are seeing issues with streaming performance and the vMix download at the same time, it likely means there is an internet issue with your connection.
The reason being our servers are not used for streaming at all (vMix will be connecting direct to them), and the vMix downloads are hosted on the Amazon CDN which servs the files from a very fast server
near to your location.
Simsyuk
#3 Posted : Sunday, January 19, 2020 8:39:20 PM(UTC)
Simsyuk
Thanks Martin. Restarted everything. Turn off the router and left for 3 mins, turned back on again and all seems fine. I'm going live today from 2pm GMT and again tonight from 8pm so it will be fully tested.
