vMix updare taking over 20 minutes
Joined: 8/16/2019(UTC) Posts: 355  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
IS anyone having problems today with vMix, my stream is just terrible (my connection is all ok, over 200mb). It's so slow. I'm trying to update to version 23.0.0.37 and it's taking over 20 minutes to install!
Joined: 1/13/2010(UTC) Posts: 5,306  Location: Gold Coast, Australia Was thanked: 4677 time(s) in 1610 post(s)
If you are seeing issues with streaming performance and the vMix download at the same time, it likely means there is an internet issue with your connection.
The reason being our servers are not used for streaming at all (vMix will be connecting direct to them), and the vMix downloads are hosted on the Amazon CDN which servs the files from a very fast server near to your location.
Martin vMix
Thanks Martin. Restarted everything. Turn off the router and left for 3 mins, turned back on again and all seems fine. I'm going live today from 2pm GMT and again tonight from 8pm so it will be fully tested.
