2MediaPro
#1 Posted : Thursday, January 2, 2020 10:34:09 PM(UTC)
2MediaPro
Spain
Hi
You know if you can record a camera or output to a NAS disk, the tests I am doing tells me the program that has to be a pc drive. I have a show where we would like to record 10-minute blocks so that the jury can access a hard drive without having to intervene.
Thanks for your time
streammediaevent
#2 Posted : Thursday, January 2, 2020 11:54:45 PM(UTC)
streammediaevent
Hello! You can map the network drive to save the recordings. You need a NAS with sufficient write speed and a wired network of at least 1Gbps to avoid problems.
Hola! Se puede mapear la unidad de red para guardar las grabaciones. Necesitas un NAS con suficiente velocidad de escritura y una red por cable de al menos 1Gbps para evitar problemas.
thanks 1 user thanked streammediaevent for this useful post.
2MediaPro on 1/3/2020(UTC)
2MediaPro
#3 Posted : Friday, January 3, 2020 1:38:16 AM(UTC)
2MediaPro
Spain
Thank you so much for everything
Yes, it is what I was looking for. I have tried what you told me and that is what I was looking for. I have mapped the RED NAS drive and it works perfectly.
Very thankful
Muchas gracias por todo
Si, es lo que buscaba. He probado lo que me has dicho y es lo que buscaba. He mapeado la unidad de RED NAS y funciona perfectamente.
Muy agradecido
thanks 1 user thanked 2MediaPro for this useful post.
streammediaevent on 1/3/2020(UTC)
