Joined: 12/29/2019(UTC) Posts: 5  Location: vigo Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi You know if you can record a camera or output to a NAS disk, the tests I am doing tells me the program that has to be a pc drive. I have a show where we would like to record 10-minute blocks so that the jury can access a hard drive without having to intervene. Thanks for your time
Joined: 8/24/2017(UTC) Posts: 21 Location: Madrid, Spain
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
Hello! You can map the network drive to save the recordings. You need a NAS with sufficient write speed and a wired network of at least 1Gbps to avoid problems.
Hola! Se puede mapear la unidad de red para guardar las grabaciones. Necesitas un NAS con suficiente velocidad de escritura y una red por cable de al menos 1Gbps para evitar problemas.
 1 user thanked streammediaevent for this useful post.
Thank you so much for everything Yes, it is what I was looking for. I have tried what you told me and that is what I was looking for. I have mapped the RED NAS drive and it works perfectly. Very thankful
Muchas gracias por todo Si, es lo que buscaba. He probado lo que me has dicho y es lo que buscaba. He mapeado la unidad de RED NAS y funciona perfectamente. Muy agradecido
 1 user thanked 2MediaPro for this useful post.
