Phil007
#1 Posted : Sunday, December 29, 2019 9:12:52 PM(UTC)
Phil007
How to apply an audio source to a specific bus? Cannot find how to do in on vMix23.
On vMix22, when I wanted to apply a source to bus (or change it to another bus) I did it on Audio Setting > Channel Matrix > selecting the desired master/headphones/buses.
On vMix23, I see there only the Master and headphones, but cannot see buses at all (see screenshot).
Following the additional c-g buses on vMix 23, does the way to apply an audio source to a bus has been changed? How do I do it now?
Audio setting
richardgatarski
#2 Posted : Sunday, December 29, 2019 9:42:34 PM(UTC)
richardgatarski
Have you enabled the buses in Audio output settings?
Phil007 on 12/29/2019(UTC)
Phil007
#3 Posted : Sunday, December 29, 2019 11:57:15 PM(UTC)
Phil007
Problem resolved. Thanks for the useful tip, @richardgatarski.
After updating to v23 the buses needed to be enabled again on the setting. Now it work as expected and also resolved a similar issue I had in vMixCall.
Thanks!
richardgatarski
#4 Posted : Monday, December 30, 2019 12:34:38 AM(UTC)
richardgatarski
you are welcome. Pls consider making a note of the solution in the other topic.
