vMix23: applying and changing audio source to a bus - Solved
How to apply an audio source to a specific bus? Cannot find how to do in on vMix23. On vMix22, when I wanted to apply a source to bus (or change it to another bus) I did it on Audio Setting > Channel Matrix > selecting the desired master/headphones/buses. On vMix23, I see there only the Master and headphones, but cannot see buses at all (see screenshot). Following the additional c-g buses on vMix 23, does the way to apply an audio source to a bus has been changed? How do I do it now?
Have you enabled the buses in Audio output settings?
 1 user thanked richardgatarski for this useful post.
Problem resolved. Thanks for the useful tip, @richardgatarski. After updating to v23 the buses needed to be enabled again on the setting. Now it work as expected and also resolved a similar issue I had in vMixCall. Thanks!
you are welcome. Pls consider making a note of the solution in the other topic.
