	SRT
	SRT Autostart
 Joined: 12/13/2019(UTC) Posts: 6  Location: AucklandThanks: 11 timesWas thanked: 1 time(s) in 1 post(s)
 I've been playing with SRT on a couple PCs, as encoders. It is working well, I'm running around 200-300ms delay from 3 remote locations over public internet.
 I've set the project file to autostart when the computer logs in. Once vMix is open I have to disable then re-enable SRT TX (caller) before I see the stream show up on the listener (RX) side.
 Has anyone run into a similar issue?
 It is easy enough to just remote into the machine and restart SRT.
 All instances are running vMix 23.0.0.32 on fresh Windows 10 installs.
	SRT
	SRT Autostart
