SRT
SRT Autostart
Joined: 12/13/2019(UTC) Posts: 6  Location: Auckland Thanks: 11 times
I've been playing with SRT on a couple PCs, as encoders. It is working well, I'm running around 200-300ms delay from 3 remote locations over public internet.
I've set the project file to autostart when the computer logs in. Once vMix is open I have to disable then re-enable SRT TX (caller) before I see the stream show up on the listener (RX) side.
Has anyone run into a similar issue?
It is easy enough to just remote into the machine and restart SRT.
All instances are running vMix 23.0.0.32 on fresh Windows 10 installs.
SRT
SRT Autostart
