Feature Requests
Asio audio buffer settings
Joined: 12/23/2017(UTC) Posts: 23 Location: Kiruna Sweden
Hello i want you to unlock the audio buffer settings
Especially for plugin use with direct monitoring from vmix Now i get echo voice when listening to the master channel when commentating sports
So i just listens to the direct monitoring of the soundcard instead, 0 latency But then i cant hear the benefits of the plugins
So please unlock the default asio audio buffer settings so that we can use a lower setting If we want to and have the cpu power to do that.
I have a behringer umc 1820 card, and want to bring in all audio sources direct to the card Instead of using a external mixer, and then can use shortcuts better for our audio that not Need to be in sync with the video.
So pleaaaase you amazing stars of vmix martin and tim.
Joined: 2/23/2017(UTC) Posts: 189 Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Install UMC Driver with the utility, you can change buffer size from the utility.
I use the control panel , set the buffer to lets say 256 All other programs work , cubase etc
But when i start vmix the buffer changes to 1024 Its so anoying
Originally Posted by: stefan svanstrom I use the control panel , set the buffer to lets say 256 All other programs work , cubase etc
But when i start vmix the buffer changes to 1024 Its so anoying We got the same problem as you Stefan! And we are in a big need of a smaller buffer size during our live events! So please vMix crew fix this!
Feature Requests
