stefan svanstrom
#1 Posted : Friday, December 13, 2019 8:47:56 AM(UTC)
stefan svanstrom
Hello i want you to unlock the audio buffer settings
Especially for plugin use with direct monitoring from vmix
Now i get echo voice when listening to the master channel when commentating sports
So i just listens to the direct monitoring of the soundcard instead, 0 latency
But then i cant hear the benefits of the plugins
So please unlock the default asio audio buffer settings so that we can use a lower setting
If we want to and have the cpu power to do that.
I have a behringer umc 1820 card, and want to bring in all audio sources direct to the card
Instead of using a external mixer, and then can use shortcuts better for our audio that not
Need to be in sync with the video.
So pleaaaase you amazing stars of vmix martin and tim.
MartLeib
#2 Posted : Friday, December 13, 2019 9:48:40 AM(UTC)
MartLeib
Estonia
Install UMC Driver with the utility, you can change buffer size from the utility.
stefan svanstrom
#3 Posted : Friday, December 13, 2019 11:06:25 PM(UTC)
stefan svanstrom
I use the control panel , set the buffer to lets say 256
All other programs work , cubase etc
But when i start vmix the buffer changes to 1024
Its so anoying
Elvis_pgc
#4 Posted : Tuesday, March 10, 2020 9:56:06 PM(UTC)
Elvis_pgc
Finland
Its so anoying
We got the same problem as you Stefan! And we are in a big need of a smaller buffer size during our live events!
So please vMix crew fix this!
