SRT
Output as "Listener" - How many callers?
Joined: 12/10/2016(UTC) Posts: 126  Location: Frankfurt, Germany Thanks: 93 times Was thanked: 19 time(s) in 14 post(s)
I saw the new SRT tutorial which helped me understand, that Caller and Listener do not have anything to do with the direction of the signals. Thanks for that! :)
Now that I know that I can have an output as a Listener, I ask myself: how man clients can connect without affecting the machines performance (i9 10 core, 1080TI)? Are 8 possible clients ok?
Regards Sebastian
Rank:: Member
You have been a member since:: 11/1/2018(UTC) Posts: 21   Location: NY Thanks: 4 times
According to the Haivision SRT Deployment Guide, I think I read you can only connect one destination to one SRT source. I tried this anyway and as soon as I connected with my 2nd destination, the video received went extremely pixelated. That being said I've got 4 available SRT outputs in my Vmix 4K, so I imagine you can set up 4 sources on different ports, but I've yet to test it. Curious to see how it works, I think my GPU card can only do 2 hardware encodes so I guess CPU will jump up. Here's the guide: https://www.vmix.com/dow...nce_Deployment_Guide.pdfEdit: In the guide they did say you can use an SRT gateway to receive a single stream and send to multiple destinations. They have an appliance for sale that does that.
When you have a Listener running, it's definitely possible to have more connections. It worked without problems with eight destinations which were configured as Callers (all with different latencies).
 1 user thanked seb666 for this useful post.
Rank:: Member
Is that so? I'll have to try it again. Can you share your setup? Vmix was the listener?
Originally Posted by: dedlinemedia  Is that so? I'll have to try it again. Can you share your setup? Vmix was the listener? Configure vMix Output as a Listener and connect to it with multiple other vMixes where the SRT Inputs connect es Callers. It works.
SRT
