Joined: 12/10/2016(UTC) Posts: 126  Location: Frankfurt, Germany Thanks: 93 times Was thanked: 19 time(s) in 14 post(s)
I want to use NDI Virtual Input with vMix Call. In Chrome I get the best quality video feeback from vMix, but I can't open the NDI virtual input. Did anyone get it running under Windows 10 and how? In my Chrome config "NewTek NDI" is standard device, but in vMix Call it shows the color bars of the vMix output.
Your description is a little confusing. It seems like you would like to use NDI Virtual Input, to use an NDI stream as a video source to a WebRTC service (vMix Call) inside Chrome. Assuming vMix as the upstream source for NDI Virtual Input, that implies the following flow: vMix --> NDI output --> NDI Virtual Input --> Chrome --> vMix Call (or other WebRTC service) Is this what you seek? I suggest you use NDI Test Pattern as a source for the virtual input. See if you can change patterns and see the change in Chrome. This is NDI Test Pattern --> Virtual Input --> Chrome --> 8x8 Video Conference  Selected Newtek NDI Video as the camera
