Hardware Compatibility
Socket connection to 3rd party hw and send commands
Joined: 2/9/2019(UTC) Posts: 8  Location: Hilversum Was thanked: 1 time(s) in 1 post(s)
I would like to control an external device for Live events. Camera's are delayed in V-Mix and cause issues with a lecturer that is talking and the image on the LED screen are delayed compared to Audio (if not running through V-Mix)
The Marshall VSW-2200 can switch HD 3G video signals seamlessly and with only 1 frame delay. Recording is done on a V-Mix system and I would like to switch the VSW-2200 using triggers, within V-Mix
For that, I need to be able to make a socket connection (TCP) and send simple commands (strings) Is there an option in V-Mix to create socket connections?
Thanks, Harpert
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
