Harpert
#1 Posted : Wednesday, November 27, 2019 10:58:57 PM(UTC)
Harpert
Netherlands
I would like to control an external device for Live events.
Camera's are delayed in V-Mix and cause issues with a lecturer that is talking and the image on the LED screen are delayed compared to Audio (if not running through V-Mix)
The Marshall VSW-2200 can switch HD 3G video signals seamlessly and with only 1 frame delay.
Recording is done on a V-Mix system and I would like to switch the VSW-2200 using triggers, within V-Mix
For that, I need to be able to make a socket connection (TCP) and send simple commands (strings)
Is there an option in V-Mix to create socket connections?
Thanks, Harpert
MartLeib
#2 Posted : Saturday, November 30, 2019 5:38:18 PM(UTC)
MartLeib
Estonia
I'm able create standalone software which would do it for you. If you are interested, contact me: mart.leib.estonia@gmail.com
