Bug? Datasource CSV parsed goes wrong
Joined: 6/5/2019(UTC) Posts: 29  Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
Code:"col1","col2","col3","col4"
"1.1","1,1","1.0","1,0"
This CSV results in col1: 1,1 col2: 11 col3: 1 col4: 10 but, i need it as col1: 1.1 col2: 1,1 col3: 1.0 col4: 1,0 JimJim XUN
check your decimal points, some are . and some are ,
Oh sorry. I forgot to tell what i need .. (i have edit my post)
JimJim XUN
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Well .. the RFC describes double quotes as "text" and not a number ... https://tools.ietf.org/html/rfc4180 -> 2.6 so .. the parser works not rfc conform ... and, a comma it not language depending. Doublequot encapsulated text should be as it is else dquotes not need :/ JimJim XUN
and what happens when you load the csv into Excel or OpenOffice Calc?
oh ... for displaying decimals, commas and periods ARE language setting dependent!
well ... this is not excel .. its vmix! and, if i want to show the remaining time of a game then the "clock/shotclock" bounce around if the time is "x.0" .. thats extreamly bad! u can see here: (1:33:15) JimJim XUN
Regardless off..Its good practice to format data properly especially with decimals and times(stopwatches) before being displayed (even the font) no matter the source to avoid displaysurprises IMO Quote:Code:Dim a as string
Dim b as Decimal
a = Input.Find("TextHD.xaml").Text("Message")
Decimal.TryParse(a, b)
a = b.ToString("###.00")
API.Function("SetText",Input:="mytitle",SelectedName:="TextHD.xaml",Value:=a )
sorry, but a good practice is to NOT manipulate incoming data! If i input "A" then it must be a "A" and not a "a" or other else Or, if i input " A " then its good to be a " A " and not trimmed to a "A" The same is for numbers if it is inside of a string block (doublequoted) It,s ok if a csv looks like and the result is Code:1
1
1.1 or 1,1 (depending on the system-language)
but a string is a fixed and not manipulatable data element (That's why DQoutes exists!). should ever be If this elementary rule will not state of the art, then i can't thrust incoming and outgoing data of a parse-process or any dataset i put into a title-data-source. The Result will be a "maybe" value! JimJim XUN
Not disagreeing with you !
maybe a feature request would be in order, quicker way of pointing this out to the admin/developer
