xun
#1 Posted : Monday, November 18, 2019 10:26:24 AM(UTC)
xun
Germany
Code:
"col1","col2","col3","col4"
"1.1","1,1","1.0","1,0"
This CSV results in
col1: 1,1
col2: 11
col3: 1
col4: 10
but, i need it as
col1: 1.1
col2: 1,1
col3: 1.0
col4: 1,0
JimJim
XUN
richardgatarski
#2 Posted : Monday, November 18, 2019 7:03:09 PM(UTC)
richardgatarski
check your decimal points, some are . and some are ,
xun
#3 Posted : Monday, November 18, 2019 7:18:30 PM(UTC)
xun
Germany
Oh sorry. I forgot to tell what i need .. (i have edit my post)
JimJim
XUN
#4 Posted : Monday, November 18, 2019 7:32:48 PM(UTC)
is normal
see the numerous post regarding this in this forum
is also depending on your language settings
also check out https://forums.vmix.com/...-Number-Format#post68503
xun
#5 Posted : Monday, November 18, 2019 9:07:26 PM(UTC)
xun
Germany
Well .. the RFC describes double quotes as "text" and not a number ... https://tools.ietf.org/html/rfc4180 -> 2.6
so .. the parser works not rfc conform ... and, a comma it not language depending. Doublequot encapsulated text should be as it is else dquotes not need :/
JimJim
XUN
#6 Posted : Monday, November 18, 2019 9:15:39 PM(UTC)
and what happens when you load the csv into Excel or OpenOffice Calc?
oh ... for displaying decimals, commas and periods ARE language setting dependent!
xun
#7 Posted : Monday, November 18, 2019 9:43:02 PM(UTC)
xun
Germany
well ... this is not excel .. its vmix!
and, if i want to show the remaining time of a game then the "clock/shotclock" bounce around if the time is "x.0" .. thats extreamly bad!
u can see here:
(1:33:15)
JimJim
XUN
#8 Posted : Monday, November 18, 2019 10:39:04 PM(UTC)
Regardless off..Its good practice to format data properly especially with decimals and times(stopwatches) before being displayed (even the font) no matter the source to avoid displaysurprises IMO
Code:
Dim a as string
Dim b as Decimal
a  = Input.Find("TextHD.xaml").Text("Message")
Decimal.TryParse(a, b)
a = b.ToString("###.00")
API.Function("SetText",Input:="mytitle",SelectedName:="TextHD.xaml",Value:=a )
xun
#9 Posted : Monday, November 18, 2019 11:01:57 PM(UTC)
xun
Germany
sorry, but a good practice is to NOT manipulate incoming data!
If i input "A" then it must be a "A" and not a "a" or other else
Or, if i input " A " then its good to be a " A " and not trimmed to a "A"
The same is for numbers if it is inside of a string block (doublequoted)
It,s ok if a csv looks like
Code:
1,1.0,1.1
and the result is
Code:
1
1
1.1 or 1,1 (depending on the system-language)
but a string is a fixed and not manipulatable data element (That's why DQoutes exists!).
Code:
" A", " 1", "1.0"
should ever be
Code:
 A
 1
1.0
If this elementary rule will not state of the art, then i can't thrust incoming and outgoing data of a parse-process or any dataset i put into a title-data-source. The Result will be a "maybe" value!
JimJim
XUN
#10 Posted : Monday, November 18, 2019 11:06:57 PM(UTC)
Not disagreeing with you !
maybe a feature request would be in order, quicker way of pointing this out to the admin/developer
