Logicone
#1 Posted : Wednesday, November 13, 2019 2:57:43 AM(UTC)
Logicone
Issue: I need two outputs: The first output, with no lower third Closed Captioning, is to be sent to Youtube and the second output, WITH Closed Captioning, to be sent to the auditorium projector.
Discussion: We are using a paid-for Closed Captioning service, Aberdeen, which provides two streams. One stream goes to Youtube and is merged with our real-time Video; (users can access the Closed Captioning with the CC button at the bottom of the screen). The second stream comes back to us via their provided App, and we display the Closed Captioning as a lower third on the auditorium projector. We send Aberdeen the Audio only via Skype.
Our problem: How do we set up two Video outputs of our Production, where the Video stream to Youtube does not have the Closed Captioning and the other Video is output to the Projector and has the Closed Captioning.
Our setup is Vmix HD and the Video card is a BM DeckLink Duo 2 (4 SDI in/out).
richardgatarski
#2 Posted : Wednesday, November 13, 2019 5:55:37 AM(UTC)
richardgatarski
You basically use the method dedcribed in a similar question (replace cliptime with captions) https://forums.vmix.com/...al-time-on-output-screen
Let me know if you don't understand and I'll help you figure it out.
Logicone on 11/14/2019(UTC)
