yinkaso
#1 Posted : Wednesday, October 23, 2019 7:11:24 PM(UTC)
yinkaso
Nigeria
Why do I only see 1 overlay channel in vMix? and my vmix supported 4 inputs only. what is the free solution?
#2 Posted : Wednesday, October 23, 2019 7:16:10 PM(UTC)
yinkaso
#3 Posted : Friday, October 25, 2019 12:34:40 AM(UTC)
yinkaso
Nigeria
It was downloaded from vmix
Joeboe
#4 Posted : Friday, October 25, 2019 1:13:11 AM(UTC)
Joeboe
You may have installed the FREE version, which has that limitation, and is only composite....I have the free version on a laptop, so I know.....you need a higher version, which if you check on vmix.com, will show you the chart with all the versions, their limitations, and the prices....so go and check
Mnd
#5 Posted : Saturday, October 26, 2019 5:47:34 PM(UTC)
Mnd
Bangladesh
If you want to full version in vmix then try to go vmix setting>about> and put up a email in 60 Days tril .....
