My Vmix allowed 4 inputs and 1 overlay only. WHY?
Why do I only see 1 overlay channel in vMix? and my vmix supported 4 inputs only. what is the free solution?
It was downloaded from vmix
You may have installed the FREE version, which has that limitation, and is only composite....I have the free version on a laptop, so I know.....you need a higher version, which if you check on vmix.com, will show you the chart with all the versions, their limitations, and the prices....so go and check
Joined: 10/26/2019(UTC) Posts: 1  Location: Narsingdi
If you want to full version in vmix then try to go vmix setting>about> and put up a email in 60 Days tril .....
