Joeboe
#1 Posted : Friday, October 18, 2019 2:44:19 PM(UTC)
Joeboe
Will this card from Aver Media (CE314-SN) work with vMix?....
Thanks in advance
sinc747
#2 Posted : Tuesday, October 29, 2019 5:10:31 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
That specific card is not listed on the Supported Hardware list (https://www.vmix.com/software/supported-hardware.aspx#capturehardware) but many other AVerMedia cards are listed. It would probably work (if you can find one).
Always make sure you can return an item like this that has not actually been tested by the vMix Hardware Testing Team.
Best wishes.
- Tom
Joeboe on 10/29/2019(UTC)
