EquilibriumTV
#1 Posted : Thursday, October 10, 2019 8:50:31 AM(UTC)
EquilibriumTV
Sweden
Hi!
Been runing vMix HD for some time and it's top notch compared to other streaming software.
I'm a gaming streamer and are using NDI Tools to send my Gaming PC to my Streaming PC.
Recently I discovered Nvidia DSR function (Dynamic Super Resolution) and are using it in a couple of my games.
The problem I have encountered is that the Scan converter are not working well with DSR, the source are being cropped into 1920x1080 but with the DSR resolution.
Is there a workaround to make the Scan converter capture the downscaled ingame resolution as my display screen are 1920x1080?
kind regards
mjgraves
#2 Posted : Friday, October 11, 2019 2:30:04 AM(UTC)
mjgraves
Scan Convertor is a Newtek product. You should direct your inquiry at them.
